okie dokie.
is this possible if so can anyone pleae tell me how?
Results 1 to 12 of 12
Just hook your VCR to the DVD and hit record, you might encounter some "macrovision" problems. Do a search om the left "DVD Hacks" to see if you can disable this for your player.
My DVD Player is connected through the VCR. In theory, just hit Record> Trouble is, Macrovision comes into play, you know, light-dark?
Some others may be able to tell you if there is a VCR that defeats it, or a hack for the DVD player to turn off Macro.
Or, if you make your own backups, you told the program to Demacro it, once burned as a backup, it should copy well.
Cheers,
George -
There's also a few "black boxes" which will filter out the macrovision from the DVD player.
"Art is making something out of nothing and selling it." - Frank Zappa -
hmm.
i have a couple home burned dvd's, that i want to copy to vhs.
which was why i was asking.
I did a hack search, and there werent any that i could do to my dvd player.
I dont know if the macro was turned off or not.
so the macro is from the dvd player itself and not the dvd? -
The macrovision is encoded into the DVD. Since you are making VHS copies of your home burned DVDs you have nothing to worry about. Just connect your DVD player to your VCR and hit record.
No, it's not. It's produced by the DVD player and the the disk has a "flag" which turns it on if it's commercially made. That's why some hacks can disable it.Originally Posted by Innershield"Art is making something out of nothing and selling it." - Frank Zappa
@St.Thanos
Why don't you just connect everything and give it a go, you have all the equipment don't you?
About the macrovision >> Only deal with a problem if you have one, AKA "If it aint broke, don't try to fix it".
Which recorder and video enhancer do I need to record my VHS tapes to DVD?
By cnyeco1 in forum Authoring (DVD)Replies: 6Last Post: 26th Oct 2013, 06:13 -
Record to DVD and transfer VHS to DVD
By TechNoob in forum Capturing and VCRReplies: 6Last Post: 23rd May 2011, 13:16 -
DVD Recorders (VHS to DVD Recorder then record raw footage and finalize)
By aeafisme23 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th May 2008, 14:39 -
Upconverting vhs to capture/record to dvd
By victoriabears in forum Capturing and VCRReplies: 1Last Post: 29th Apr 2008, 13:17 -
HELP: Looking for a GOOD DVD VHS combo - Don't need to record just play...
By UNOWEN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Sep 2007, 12:24
