  1. The audio plays fine on the MPEG-1 encoded by TMPEnc. But, once it is burned, then played, the audoio is out of sync. I read an earlier post regarding the audio sampling rate may be wrong. But, I know I set it to 44100 in TMPEnc. It wont let you encode it otherwise. Should I be doing something to the audio in DVD2AVI????
    Demonio
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    There are two types of desync - offset , where the audio constantly lags or leads the video by the same amount over the whole film,
    and drift, where they start in sync but get progressively further apart as the movie goes on.
    Which one do you have ?
    If in doubt, Google it.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    If the mpeg is Ok then it has to be your burning method, your media or your player. How is the sync when you play the disk in your computer? Are you burning with nero or something else? What is your burning speed? Good disks? Not making an XVCD by chance? Have you tried the disks in another player?
  4. I have this one --> and drift, where they start in sync but get progressively further apart as the movie goes on.
    this is what i am doing:
    1)ripping dvd (smartripper)
    2)framsserving (dvd2avi)
    3)encoding mpeg-1 file for VCD burn. During this I am chaning the bitrate 'n stuff so it fits on one CD. Could this be the problem???
    4)burning mpeg-1 to VCD
    kthe final mpeg-1 file produced by tmpenc has the above-mentioned lag. fine in the beginnning.
    oh, and this happens whether it is DVD->VCD, or Divx->VCD
    thanks for the quick reply.
    Demonio
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    When you use dvd2avi are you using dolby surround downmix and are you outputting to wav? Do you get a d2v and wav?
  6. I dont think I am using any dolby audio options. just the normalization and no 48->41mhz.
    I do get a d2v and a wav file.
