I'm trying to make a multi title DVD in DVDLab because of the freedom with the menus (no templates). I've done several of these with tmpegnc dvd author but I was trying to get a new look and keep motion menus. It will let me load the mpeg1 files (I've tried with vob files too) when I add them to the movie no picture show in the preview screen and when I try to add chapters the program will crash. I know the program description states that it supports mpeg1 is there something I'm not doing? Or is there a better software I should be trying?
Thanks in advance
MPEG1 does not have a preview, the preview box will just display green, and as far as I know, you can't add chapters like you do in an MPEG2 file. You'll have to chop up the "VCD" into it's parts for chapters, or you would have to create a DVD-VCD.
Windows Explorer crashing when trying to rename/play video files over 5GB?
By yatesl in forum Software PlayingReplies: 4Last Post: 18th Dec 2011, 20:19 -
G4 Keeps Crashing When Converting avi Files to dv
By elsiejazz in forum MacReplies: 3Last Post: 22nd Jun 2009, 05:24 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15 -
any tool for converting vob files to mpeg1?
By sumeshkri in forum DVD RippingReplies: 8Last Post: 18th Feb 2008, 23:22 -
VOB to MPEG1 (mpeg2enc) Failure
By speedreader in forum ffmpegX general discussionReplies: 7Last Post: 1st Aug 2007, 21:07
