I have edited (censored) a number of DVD movies so that the kids can watch them. Now my oldest wants to listen to the commentaries of certain movies. Since I'm the nice dad that I am I said I would try to include the commentary tracks when I edit a movie.
Editing a DVD while keeping multiple audio tracks seems to be a more complicated task. The following is my proposed process recipe.
DVDDecryptor - spliting the video, audio, and subtitle segments
Subrip - to transfer subtitles to a text file to search for cus words
HeadAC3he - transfer AC3 audio tracks to WAV
WavePurity - Audio editor to fill cus word segments with silence
TMPGEnc- convert WAV tracks to MP2
IfoEdit - combine video and multiple audio MP2 tracks to VOBs
DVDShrink - cut out certain sex and violence scenes [I know, some of you probably would like to cut out everything else]. I don't know of another program than can edit VOBs with multiple audio. I also can’t think of a cheap or free program than can edit un-encoded video and multiple audio tracks simultaneously.
DVDLab - Author the VOBs
Is there a better way?
There are some cheap solution tu edit/cut multiple audio tracks simultaneusly but since I'm against censoring, I wont tell you
Originally Posted by Milo
chaseru
If you cut less than 10 parts out of the movie, you could use DVD Shrink.
Rip the movie to HD (all files) and use DVD Shrink with the re-author feature and select the start-end points for each title. DVD Shrink will make a seperate titleset for each clip. all the audio and subtitle tracks will be there. The chapters will be re-numbered for each titleset.
Hope this helps
Chas
DVD to h.264 -- with multiple audio and subtitle tracks
By Ozo in forum DVD RippingReplies: 12Last Post: 16th Nov 2012, 06:34 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
m2v and ac3 multiple audio tracks to DVD
By gameroftheuk in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 15:55 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
VOB to .ts with multiple audio tracks
By csaba1985 in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2007, 07:28
