Dear Friends,
The firmware update process (ver. 2.30rev) could not be completed in my machine and now i'm not capable to use this drive. Neither the BIOS can detect this drive... Is it dead or there's something else to do?
Any help will be much apreciated...
1.Unplug IDE cable to Optorite then bootup and shutdown,connect drive and bootup.
2.Reinstall firmware,if you use Windows installer disable DMA or use PIO mode!
3.The drive has a one year warranty so contact who you bought it from or Optorite support: www.optorite.com/support.htm -
I have been done this. But the drive is not booting yet.
It's not reconized by BIOS. Any other drive connect in same IDE Channel does not boot too.
There's another thing i could try? -
Try following the instructions outlined in the first post from the following link:Originally Posted by alxsoft
http://forum.cdfreaks.com/showthread.php?s=eecf39a8b1fd77d3e574f73b7e467910&threadid=81136
If this still doesn't work, then sending it back for warranty repair is your only choice. Good luck. -
unfortunally, the process was not capable to complete properly. My drive is still dead
I guess i have to return this drive -
If you've connected other drives to that channel and NONE of them work, then the problem is not the Optorite. Could be a dead channel (unlikely), could be a bad cable, could be a BIOS setting. Find out how to access your BIOS setup and check to make sure that the IDE channel in question is enabled. Make sure none of the pins in the connector on the board are broken or smooshed.
Best of Luck,
-Evan-
GE DV1 No Firmware Update What Is Up??
By DJboutit in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2011, 23:16 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 14:52 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 23:46 -
Firmware Update Question ##
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2008, 07:56 -
DVR1112D firmware update?
By videobread in forum DVD & Blu-ray WritersReplies: 3Last Post: 15th Sep 2007, 21:02
