Hi all, i am trying to burn a movie to disk using nero but it says it is not video cd compliant and will reincode to video cd format, the movie started as an avi which i used tmpgenc to convert i loaded the unlock file and changed all the settings i needed to change, 8 hours later and nero does this.
Can anyone help please
Results 1 to 12 of 12
Burn it as non-complient.
Is it really VCD and not SVCD?
Did you do the Audio Correctly?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
No! Don't do it! Don't let Nero re-encode your file.Originally Posted by jimmalenko
@highlander- Since you had to use the unlock template it seems that you made a file that is not 100% VCD compliant. If you use one of the regular VCD templates without unlocking then you will normally create a compliant file. Burn it as non-compliant like Gazorgan said, if nero won't do that then VCDEasy will."Art is making something out of nothing and selling it." - Frank Zappa -
thanks to all for helping, i did it as non-compliant then burned it no problem until i put in my dvd and played it, there is a green line down the whole screen and covering about 1/3rd of the picture, any ideas??
Try using TMPGEnc's templates to make a compliant file in the first place.
If you unlock the template and fiddle with the settings, you're making an XVCD (i.e. a non-compliant file/disc).
If you do this, you shouldn't be surpised when Nero says the file is non-compliant, and you encounter problems playing the disc on your standalone.
cheers,
mcdruid. -
i will give that a try and if i have anymore probs will get back thanks
Encoding SD video with H.264 to be 100% Blu-ray compliant.
By PuzZLeR in forum User guidesReplies: 14Last Post: 19th Oct 2015, 18:12 -
Rebuild split ipod m4v and convert to PC-Compliant Video?
By flemmo in forum Video ConversionReplies: 4Last Post: 3rd Apr 2009, 17:10 -
Trim start and end of MPEG2 compliant video.
By mattstan in forum EditingReplies: 5Last Post: 25th Feb 2008, 11:06 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 20:00
