when i use to play my divx movies they worked great. now since i got my new computer the sound is good but the video is kinda jumpy and its green?
anyone know how to fix it
Yep! You've got an old/wrong/missing codec issue.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I dont use a pack, I followed the link in the tools section for divx 3.11, 4, 5 and xvid. if i come accross something i can play i check the file and get the required codec. some of those packs contain adware/spyware so be carefull of those.
Hi,
I had a similar problem with XVID's. I have found that codec are picky and when intalling the same codec over the same codec and also picky about using old codec's. Codec like the updates.
What did to fix it was uninstall the nimo's codec pack, which the codec that use for mine sometimes. Then I found out that is still leaves some of the codec's behind so I manually went though and deleted all the divx codec, XVID codec.
If you decide to intall the nimo's codec do not install ffdshow because nimo uses a older version of ffdshow.
Another codec pack that I like to use instead of nimo's sometimes is called Gordian Knot, which works well also.
I hope that it helps.
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 15:39 -
any quicktime movies go green
By matneaves in forum Software PlayingReplies: 4Last Post: 5th Aug 2007, 16:00 -
Burning Divx movies with subtitles?
By Hank Kinsley in forum SubtitleReplies: 5Last Post: 17th Jul 2007, 12:33 -
DivX Video with Green Lines
By sweetfreek in forum Software PlayingReplies: 5Last Post: 23rd Jun 2007, 15:05 -
Divx Video Playback is green
By littlemiss in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2007, 14:51
