Hi guys
I have a small(?) question.
I am having audio sync problems with this SVCD - VCD Trick on my DVD Player (SONY DVP-NS400D). So I was going through different threads to find a solution.
Then I saw this interesting phrase/word "SVCD BOOT DISK" (to make a dvd player recognise SVCDs).
Is there anything like a "SVCD BOOT DISK" to make dvd player recognise SVCD even though they are not capable of reading SVCDs ?
If yes, how to make these Boot Disks ?
Can someone please help me with this ...
Thank you
Ram Ram
Most players don't boot from CD except for very specific BIOS upgrades. You have to make an image with exact parameters. I'd say no for standard players.
For PS2/XBOX then maybe yes?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Gazorgan...
I was wondering if I can do anything to make my dvd player recognise SVCDs. Then I found that.
Anyway, Thank you very much for the information.
Do you have any clue on how to get rid of the audio sync problem I have when I use the VCD Header trick and play on my Sony dvd player ? (when I play the same cd-r on my computer player, it plays well).
Ram Ram -
The whole concept of a SVCD "boot disc" is wrong.
If your DVD player doesn't recognise standard SVCDs, then it doesn't recognise SVCDs. Unless there is a firmware upgrade available for your player that fixes this, then there is nothing you can do.
You could always try to use the "header" trick (which means in essence you are making an XVCD but with SVCD style MPEG-2 source files) but if that doesn't work, well, you don't have too many options left.
Regards.Michael Tam
w: Morsels of Evidence -
Try different Audio Bitrates for the MPEG encode. A Lower bitrate fixed the sync problem on my Teac DVD player.
Thank you guys
I got my doubt cleared about the "svcd boot disc" concept.
Now it looks like, the only options I have are... either go for a different DVD Player which supports SVCD format or re-encode my SVCDs to VCD.
And thank you widemouth, I will keep that mind when I re-encode my mpegs.Try different Audio Bitrates for the MPEG encode. A Lower bitrate fixed the sync problem on my Teac DVD player.
Thanks again for all that information.
Ram
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 02:06 -
Hard disk damage or corrupt boot manager? [Solved]
By Sakuya in forum ComputerReplies: 15Last Post: 5th Jun 2010, 00:33 -
Is there easy way to create Win2k boot disk with command prompt available?
By bevills1 in forum ComputerReplies: 9Last Post: 10th Apr 2008, 12:25 -
PE Builder Boot Disk
By scustalow in forum ComputerReplies: 2Last Post: 14th Nov 2007, 15:21 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 14:48
