  1. Please can anybody tell me if AZO 4x discs are any good and if they will work on a pioneer 106 as i can not find any info on them
    Thank You
  2. I believe AZO refers to the type of dye. There are other factors at play in determining whether the media is high quality or not. I bought some very cheap PRIMEON AZO discs, and while they burn at x4, the last 5% of the disc doesn't verify. They're fine if you burn at lower speed or keep below 4GB per disc. Better quality discs with the same azo dye may well be fine. In other words - suck it and see!
  3. I used some Verbatim with Advanced AZO, they all faild to play.........
