I am thinking about buying the HP300e.When I record from my vcr do I have to put it on my hard drive first? Has anybody used any of these software bundles Software included: ArcSoft ShowBiz DVD; Veritas RecordNow, DLA, and Simple Backup; HP Memories Disc Creator; CyberLink PowerDVD; ArcSoft Multimedia Email. I am using the AVerMedia USB2.0 DVD EZmaker Video Capture Device to make vcds.
That unit is just an external burner. You would have to capture the video to your hard drive first.
HP also makes a burner that has video inputs so you can directly connect the vcr to it. It is also a normal external burner for the pc. It will capture directly to the disc. I haven't used it, so I don't know the quality if the capture.
Here is a link to the page with it on hp's site:
http://h30015.www3.hp.com/dvd/content/index.asp
recording test pattern on a vcr from PC
By mammo1789 in forum Capturing and VCRReplies: 11Last Post: 13th Apr 2012, 10:59 -
Need LG897T dummy instructions on VCR recording
By Astrovel in forum DVD & Blu-ray RecordersReplies: 5Last Post: 7th Mar 2009, 00:45 -
Recording in VCR Mode
By mapmaker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2008, 19:23 -
HDTV VCR recording, VHS TAPE?
By jb66 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 18:45 -
What is the exact physical point where recording happens vcr and a tape ?
By arturock in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2008, 22:15
