I have a 720x576 (4:3) PAL mpeg and I would like to convert it to a VCD.
What settings would I need both in VirtualDub(resize) & TMPGEnc to keep its original width.
I read & read & tried with some success, but not what I wanted (borders on all sides)
(audio & fps is figured out)
Results 1 to 10 of 10
Do you mean a PAL Svcd or NTSC.Originally Posted by richz
Anyway, it shouldn't really matter, just use TmpGenc (no need for vdub) and set video arrange method to Full screen (keep aspect ratio) and set Aspect ratio to 4:3 Display. That should work.
Oh, and preview the output in a proper software DVD player like pwoerDVD, not WMP as it usually ignores the DAR setting. -
I could work that bit out, but what is your intended destination, I know its VCD but do you want Pal or NTSC.Originally Posted by richz
Anyway, whatever you are trying to do, the settings I have given should be correct as far as Aspect ratios go. -
You can't. VCD is roughly 1/4 the area of full DVD. Try SVCD it's much higher resolution.
Alternately, try a different arrangement method, TMPG has to do some cutting to get the right display resolution for PAL->NTSC conversion.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
You need the folowing:
On the Video tab of settings
Aspect Ratio 4:3 display (VCD does not support anything else)
On the Advanced tab of settings
Source aspect ratio 4:3 625 line (PAL)
Video arrange method - Full screen (keep aspect ratio) (may want to try keep aspect ratio 2)
PAR and/or DAR prolem, not sure which
By fatcharlie in forum Video ConversionReplies: 3Last Post: 26th Apr 2011, 15:48 -
Virtualdub: DAR?
By higgins327 in forum Video ConversionReplies: 4Last Post: 1st Apr 2011, 06:42 -
Question on DAR and best image size for a pal movie menu background
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2011, 10:42 -
Dar, sar...
By drgt in forum Newbie / General discussionsReplies: 44Last Post: 13th Dec 2010, 13:09 -
Change DAR of MPEG-1?
By vonzippa in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2008, 20:17
