Thinking about buying a e-50. But, one BIG problem! Does it not play svcd?
Results 1 to 12 of 12
Originally Posted by pezmannen
No, unfortunatelly Panasonic dvd recorders (and players, I believe), do not play svcd. -
My DVDS75EBS plays SVCDs. My mum has an E50 - i shall check that tonight for SVCD. It does however play SVCD on DVDs (DVD-SVCD)
From manual
Discs that cannot be played
DVD-Video with a region number other than 1 or ALL
=12-cm (5z), 2.6- and 5.2-GB DVD-RAM
=DVD-RAM not recorded following the Video Recording Standard
=3.95- and 4.7-GB DVD-R for Authoring
=Unfinalized DVD-R recorded on other equipment
=PAL discs =DVD-ROM =DVD-RW =DVD-Audio
=+RW =CD-ROM =CDV =CD-G
=Photo CD =CVD =SVCD =SACD
=MV-Disc =PD =Divx Video Disc, etc.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
SVCD is used so little, I wouldnt bother adding it to my DVD recorder (if i made one!). How many people actually own an original SVCD disc ?. Ive never seen one, the only original VCDs I own are the Star Wars Trilogy Box Set.
Tell you the truth. If I buy DVD Recorder, I will record with it and I will not use it to play since I would like to keep it as long as I can
Originally Posted by donpedro
Absolutely in agreement with you on that!! They're darn near GIVING DVD players away these days. Don't waste that expensive DVD recorder laser on playback!!!
thoots -
Originally Posted by andydd
and since its probably not that hard to make a dvd player play and accept all formats when u are designing it why not allow it to play everything.........just don't support it in the manuals...that would be a better get out clause IMHO.
it won't even play CVD's which i'm told are a legit resolution for dvd players? -
Just tested SVCD in DMR-E80H. It was thinking that it is VCD and could not handle higher bittrate. Very-very choppy. Just thought to share my experience.
"andydd" "thoots" There nothing wrong about making a DVD player able to play SVCD if you do not use it what do you care, but if some else has a reason for it. It's better to support the VCD and SVCD format. Just give more reason to buy that product. I see this from a marketing point of view.
There are ton's of people that use SVCD people that capture TV show's. SVCD is very easy to use just burn MPEG 2 file and pop the disc in. Alot of people like SVCD better the DVD. one hour show one disc in VBR mode and CBR mode one half hour show or two half hour show in VBR mode. People at www.dazzlegeek.com burn alot of SVCD. Alot of people start to use SVCD format when DVD burner's cost an arm and a leg.Even when the Pioneer AO3 came out it was $500.00 dollars and $10.00 dollar's for one DVD-R.
There are alot of thing we do and not do. Just because you do not do some thing does not mean there's no one else doing it. Hell I hate the "LIFETIME NETOWORK" would I cancel the network. No there some one out there adn I do not kow where but there some watching that network.
What I'm saying if there no extra cost or a very small amount make your product the best. Do not give other people a reason to buy another product.
I have APEX AD-5131 DVD player best DVD player for SVCD's and VCD's. I also have Pioneer DVD, JVC DVD player, and a Sony DVD player all support VCD and SVCD
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 20:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 13:09 -
Panasonic dmr es-15
By jean1938 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 18th Jun 2008, 03:31 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 12:34
