I can get DVIX to convert to MPEG then turn it into a DVD, But if i try to do a XVID the Sound and Video is out. (this happens all the time on anything i do). Is the a program that will do it. Hopefully, one program. Thx in advance. Sam
TmpGenc, amongst others, will convert Xvid to DVD compliant mpeg-2. You can then author and burn.
The audio sync problem could be many things. The most likley that I can think of is the use of VBR audio in the avi file. Open the file in virtualdub. If it gives a warning about vbr audio, that is the problem. Search the forum for solutions as they are simple and have been detailed many times. -
There is only 1 basic difference between XviD and DivX, and a computer completely ignores it (but not standalone players).
The ultimate problem is your renderer (the codec that breaks XviD down so TMPGEnc can re-encode it). Do you have the XviD codec installed? Usually an old XviD codec is the problem. Search Fourcc changer, and reset the avi to divx/divx and see if that works?To Be, Or, Not To Be, That, Is The Gazorgan Plan
Decent DVD recorder that plays AVI (DivX & XviD MPEG-4) w/HDMI out?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Feb 2012, 20:20 -
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 13th Dec 2009, 00:44 -
DVD/vob/mpeg to Avi/xvid automated process, Help!
By sinz in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 02:08 -
XviD MPEG-4 to DVD with Subtitles
By MI6 in forum Video ConversionReplies: 1Last Post: 3rd Jan 2009, 06:09 -
xvid to mpeg 2
By DSLGuy in forum Video ConversionReplies: 2Last Post: 13th Oct 2007, 12:27
