Results 1 to 18 of 18
    Dec 2003
    South Africa
    Hi Everybody, I recently purchased a Cyberhome 1500 DVD Recorder , with it comes three DVD - RW , I made a recording on one of them and tried to play it back on my son's Sansui DVD player unfortunately his player would not playback and gives an error unknown format. Having read the manual I realized one had to finalize the DVD before playingback on other DVD players. I enterd the Record media menu in the setup options and there are two options available one to erase the DVD and the other to finalize the DVD, I am only able to access the erase function the menu does not allow me to scroll to the finalize option.
    I would really appreciate some help fron you guys.
    PS. I read the review by mp3superfreak and was most impressed by it.
    Feb 2002
    Bull's eye - NY, ny usa
    In the menu, DVD+RW is made "Compatible"
    and DVD+R is "Finalized"
    That is why you can't "Finalize" a RW disc
    Dec 2003
    South Africa
    Hi Zleepy
    I cannot find in the menu a the "Compatable" function, perhaps you can advise me where it is hidden. Many Thanks
  4. When in the menu press edit on the title and then select "Make Compatible". Depending on how many edits you have made it may take a while so be patient.
    Be warned that it may appear that it has completed it but it has not until the title is highlighted again.
  5. singh,
    You don't need to finalize DVD+RW. Try using DVD+R (don't forget to finalize it) as it is more compatible/reflective than DVD+RW.
  6. I believe that "Make Compatible" is available only when you EDIT.
  7. Hi, Are you sure the cyberhome 1500 can record DVD - RW? The specifications I found on the net say it's a +R and +RW recorder.
    Also, I just won an auction for a cyberhome 1500 on e-bay and now I'm looking for the best media W+ to transfer VHS videotapes to DVD media to play on a Cyberhome 500. Any suggestions/experiences?
    Thank you
  8. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Thank you
    The Cyberhome CH-DVD 500 does not like DVD+R discs but will play DVD+RW discs. Sounds like it should be the other way around but that is not reality.
    - John "FulciLives" Coleman
  9. Thanks for the info John. Well, since I'm looking to burn 100+ discs I don't see me buying that many +RW. So I guess I'm forced to record the tapes using first the cyberhome 1500 Rw+ and then passing the info to -R using a computer DVD rewriter (pioneer 106 I'm planning to buy). I hope at least the -R will work well with the cyberhome 500...not?.
    Do you know a better (cheaper or faster) way to do it?
    Luis
  10. Member FulciLives's Avatar
    May 2003
    Luis
    Computer method to DVD-R should work well. Just don't use NERO to burn the DVD. I suggest using the classic version of ImgTools along with DVD Decrypter. When I use TMPGEnc DVD Author I use that program to create the ISO IMAGE but then I always burn with DVD Decrypter.
    I've heard that many people have no problem using TMPGEnc DVD Author to import DVD+RW discs ... do simple editing ... then output for burning to a DVD-R and I too have done this myself (with DVD+RW discs made on a Philips stand alone) but lately a few people claim to get audio sync problems with this method when using DVD+RW discs that were recorded on a Cyberhome 1500 so I don't know if there is some "odd" issue with the Cyberhome 1500 or if it is simply user error in TMPGEnc DVD Author that is the cause of the audio sync problems.
  11. Thanks again John. I'll try that as soon I receive the cyberhome 1500. I need yet to decide what media brand & speed I'm going to use. I've heard TDK -Rx2 works well but I'll like to know your opinion, any advice?
    Luis
  12. Member FulciLives's Avatar
    May 2003
    Luis
    Well I only use DVD-R media. I do have some DVD+RW discs that a friend gave me but for my own use I prefer DVD-R so I can't offer any assistance when it comes to DVD+R or DVD+RW etc.
    However as far as DVD-R goes you simply CANNOT beat the Taiyo-Yuden brand. You can buy them direct from some on-line sources such as RIMA.COM or you can buy them in stores under the FUJI brand.
    Please note that not all FUJI DVD-R discs are Taiyo-Yuden. Only the FUJI DVD-R discs that say MADE IN JAPAN are Taiyo-Yuden. So far they only come in a 10-pack with each DVD-R in a full sized CD style jewel case. The larger "cake" packs of FUJI DVD-R discs say MADE IN TAIWAN and are typically RITEK G03 discs.
    The 10-pack MAXELL DVD-R discs are also very good and come packaged just like the FUJI in full sized CD style jewel cases.
    The FUJI 10-packs can be found at BEST BUY and somtimes CompUSA whereas lately only WAL-MART seems to carry the MAXELL 10-packs (and I think there is also a 5 pack version).
    TDK DVD-R discs are good but only if the package says MADE IN JAPAN otherwise they say MADE IN TAIWAN and are RITEK G03 or if you are lucky RITEK G04 discs.
    The 10-pack FUJI DVD-R discs are $24.99 at BEST BUY which is where I buy them since CompUSA wants $29.99 for the same thing. The 10-packs of MAXELL are something like $23.99 at WAL-MART but I don't care much for WAL-MART and avoid them if I can. The TDK discs I'm not as sure about price wise but again look for that MADE IN JAPAN. I bought a 5 pack of TDK DVD-R discs at TARGET a few weeks back and they said MADE IN JAPAN and worked really well.
    I've yet to buy Taiyo-Yuden direct but RIMA.COM has the best price I've seen at $168.00 per cake pack of 100 4x DVD-R discs but I never bought them that way because although that is cheaper per disc than the FUJI way ... well ... I never seem to have $168.00 at any one time to order that many at once!
    I was in BEST BUY last week and looked at the DVD+R discs just for shits and giggles. I wanted to see if any of them said MADE IN JAPAN. I couldn't find one package of DVD+R discs that said that.
    MADE IN JAPAN DVD-R is the way to go for me
    P.S.
    Many people say the RITEK G04 discs are good but lately people have been SOMETIMES getting bad batches. That scares me.
    Feb 2002
    A Recent Report On Nero - by gpwake on Dec 14, 2003 19:04
    https://www.videohelp.com/forum/viewtopic.php?t=193511&highlight=cyberhome
    "With the new version of Nero I am able to use the VOB files directly from my cyberhome 1500 burned DVD's! This is the first software package that I have been able to do this with...Previously I needed to frist RIP the burned DVD's to my HDrive, then import them into TMPGEnc DVD Author or DVD lab...Just thought I would share my findings.
    "I am SOLD on Nero 6! Recode also works GREAT...I have used it to make several backup copies of my DVD movies. Used it to fit Finding Nemo on one 4.7GB DVD+R and it worked GREAT!"
    FWIW While the Cyberhome site is down, files can be coppied to your folder from:
    ftp://209.237.61.78/cyberhome/1500
    2x click the selected folder and copy files to your desktop or folder.
    Sorry for my non reply, I've been off line upgrading my system.
    Dec 2003
    Rochester, NY
    Is there a way to make this recorder region free?
    For general information I have great success with Memorex media in this recorder.
    Thanks all
    Brian
  15. Hack on this very site here
    Webmaster of Area 450, the independent site for owners of Sampo and Maxent DVD products the world over
  16. Is there anyway around the macrovision detection?I just want to copy some of my favorite old movies to dvd before the tapes degrade further.Thanks.
  17. Yes there is. Take a look at this thread... https://www.videohelp.com/forum/viewtopic.php?t=190459
  18. Originally Posted by davwilled
    Yes... there is a couple of posts about that. Try search if you can find some.
