I am converting an AVI to MPG and burning to SVCD. I made the AVI myself, and some of the audio was not very high quality, but plays all right. On the SVCD the audio that was not as high quality does not play right on my DVD player, but it does play fine on my PC. The audio that is higher quality plays fine, but the lower quality stuff is very muted. I have tried different bit rates for converting AVI to MPG, but not much help. Any suggestions??? I would really like to be able to get this to work.
Could you mention which software you are using to encode?
If you are at anytime converting the audio part to a wav, you should use an audio program (there are so many around) to emphasize quite bits, take out noise etc. And then mux the audio and video back together again. -
I am using Ulead Media Studio Pro 6, with their new DVD plug-in. I believe that it uses a Ligo's codec for the encoding. The lower quality audio used to make the AVI were some sound clips I downloaded off the web in WAV format. Can you elaborate on what I should do exactly to the audio? Thanks
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
What I meant was that you take the audio part and use filters that usually come with the audio mixing software (noise, echo, bass etc.) to emphasize the audio portion of your file, so that it sounds better. It's a lot of work but if you are persistent you can do it!
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 16:12 -
audio problems...............
By themediaman in forum Video Streaming DownloadingReplies: 6Last Post: 25th Dec 2010, 17:43 -
audio problems
By minigamer in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2008, 11:03 -
Audio Problems
By macuser1960 in forum ffmpegX general discussionReplies: 9Last Post: 26th Feb 2008, 14:46 -
Problems w/Audio
By itsmevic in forum AudioReplies: 1Last Post: 9th May 2007, 00:53
