I am looking for a fairly pro or semi-pro piece of software that I can make and print my own calenders from using my own digital photos. I see some cheesy sharware programs are available at download.com but these aren't very good in my opinion. I am looking for something a little higher end.
Does any body have any suggestions?
thx.
Tygrus
Tygrus2000,
http://www.easycalendarmaker.com/
If you don't like that, then visit http://www.versiontracker.com and search again. That's how I can across that one.
CobraDMX -
Since you didn't specify what OS, I'll suggest iCal for OS X. Great freeware program for calenders.
I tried Easy Calender and its a good program, however I am looking for something that can write out the format to an actual image file that I cna take down to the local photo store and have printed out.
Anyone have suggestions?
tygrus -
Do you have MS Office? MS Publisher got a feature for your own customized calendar making.Originally Posted by tygrus2000
I do this every year using MS Publisher as a very plain calendar. I just did one very quickly for year 2004 and no problem. I manually added the events and the public holidays into it.
There are different designs available. I think you can modify and make your own design, the size, and the color, insert your own image and the graphics and so on.
This is a lot cheaper than buying one. The only thing, I don't have a color printer for the photos and the graphics.
I gave a copy of my calendar to a friend.
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
