Just found out about this utility for detecting errors on cdrs using lite-on drives. Ran tests on 2 types of Fuji CDRs...one is Taiyo Yuden, the other is Prodisc Technology. Used the default settings, and am wondering what the results mean?
Prodisc Tech
Max Total Average
C1 14 2580 .652
C2 0 0 0
Taiyo Yuden
Max Total Average
C1 9 1978 .485
C2 0 0 0
What is C1 and C2? SHould I be concerned with the new Prodisc Technology made Fujifilm CDRs? Both play fine, but I wonder what the larger numbers for the Prodisc Fujifilm CDRs mean? Taiyo yuden makes cyanine and Prodisc uses phtalocyanine dyes.
I recall seeing a bunch of threads covering k-probe over at doom9.
To me, your results look the same for both discs. I think C1 is a recoverable error, C2 is not. Can't really recall though. There was some debate about this.
I do know, that results varry widely depending on the drive. So comparisons with k-probe are inquestion unless they all come from the same drive. As your's did. -
Here is a link to the CD-Rinfo forum that has a Write quality document you can download. It explains C1/C2 errors. Basically, C1 are errors that can be corrected by the drive, C2 errors can be corrected but it depends on error length. The one parameter that Kprobe does not measure is C3(E32) errors. These are errors that cannot be corrected. This would be the Pop sound that you hear on a audio disk playback.
http://www.cdr-info.com/forum/topic.asp?TOPIC_ID=8458
RG -
@Mocha,those scores are very good.
C1 errors are write errors and can be caused by:
1.Using outdated firmware
2.Poor quality media
3.Overburning
4.Using outdated burn software
5.Burning at high speed
C2 errors are usually caused by:
1.Physical damage-scratches,labels,ball point pens,etc.
If I get less than these scores I'm happy:
C1 max-20
C1 avg-2.5%
C2 max/avg-0
...and of course DVD's use Tilt Analysis to test Parity Inner/Parity Outer(PI/PO). -
tHANKS FOR THE REPLIES!!
I normally burn at the highest speed allowed by Nero...I first have Nero do a speed test....usually it burns between 32x and 48x....my max burn speed is 52x.
Thermal Probe Placement
By AuroEdge in forum ComputerReplies: 2Last Post: 10th Feb 2010, 07:19 -
Mosaic Looking Results
By treed68 in forum DVD RippingReplies: 5Last Post: 27th Jul 2008, 04:20 -
What can I do for best picture results?
By BrokenOne in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2008, 15:22 -
How to interpret DVD Infopro Graphs ?
By cd090580 in forum MediaReplies: 0Last Post: 20th Mar 2008, 13:41 -
Help with Gspot Results
By Dawter in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2007, 07:01
