I've been using TMPGEnc and many other programs for movies and such for a long time now, and everything's working fine, but I just want to know what the two fields are? When you get a choice between field A or B first, what is it talking about? Thanks everyone, this one should be easy for you guys.
A=Odd field first
B=Even field first
Most TV's will play both fine but you should make a small video and put on CD-RW/DVD-RW to test,if you see "stepping" or "jitters" then you know what field order to use.
www.greatdv.com/video/fields.htm
converting 60 unique fields ps
By spiritgumm in forum Video ConversionReplies: 98Last Post: 17th Oct 2011, 21:22 -
Blank fields in Subtitle Workshhop.
By Belfour in forum SubtitleReplies: 0Last Post: 27th Aug 2009, 07:08 -
Fields problem
By themaster1 in forum RestorationReplies: 4Last Post: 14th Oct 2008, 19:27 -
Newbie frame/ field - capture both interlaced fields
By peter bradbeer in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 8th Feb 2008, 15:36 -
AVCHD - upper fields or lower?
By tat2jr in forum Video ConversionReplies: 8Last Post: 29th Jul 2007, 12:38
