ok i want to be able to get film off my tape camera so im gona buy a tv tuner (cheap one but not a bad one) and then buy a connector for tv's when they dont have the rca ports..if you know what i mean. its like 17 bucks at walmart
will this work?
If I read your post correctly, you want to use a TV tuner card and capture using an RF modulator to convert an RCA composite to a channel 3 or 4 signal?
The setup would work, assuming the tuner card allows you to capture video from the card (if not, then i guess you're SOL). The only problem I see is the quality, since a signal on a channel 3 or 4 frequency would be lower quality than a composite or component connection, but if you have good cables and little to no interference, then you should be okay.
You could also connect your VCR coax output to the tuner card directly and avoid buying a modulator. -
HAHA finally someone said something like that
ive been posting around too see if i could do that and nobody knew that i was talking about...(the vcr thing) alright i think im gona just use my vcr it would be cheaper
thanks!
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 23:39 -
tv tuner
By maryhigginsrice in forum Newbie / General discussionsReplies: 7Last Post: 17th Dec 2008, 19:07 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42 -
TV Tuner Help!
By anony283 in forum Capturing and VCRReplies: 13Last Post: 30th Apr 2008, 10:30 -
High Definition TV? Tuner or no Tuner?
By aturjans in forum DVB / IPTVReplies: 6Last Post: 17th Mar 2008, 08:31
