Is it possible for me to edit dv once it is on dvd?
That is a bit of a cryptic response IGH529 for a response to a newbie.
Although you are of course right.
Nerie, once it is on the DVD you will have completed any work you are aiming to do. The dv capture (normally in AVI format) is the stage where you will want to be editing. From there you would then encode to a DVD compliant format such as MPEG2 before authoring a DVD.
In short the DVD stage is the final one, all editing is completed beforehand.
There is loads of stuff in this forum about it all so read away! -
View the disk contents in explorer, if there's two folders in there...Originally Posted by nerie
VIDEO_TS and AUDIO_TS (the folders necessary for a DVD compliant disk) then you're buggered.
If there's a file on there called bigboobs.avi (ie. someone has simply archived the DV footage to a DVDr disk) then yes, you could just copy the file back to your PC and edit.
If it's bigboobs.mpg then its a DV file which has been encoded to mpeg2 (the file format for DVD) and whilst unwise yes, you can edit an mpeg2 file (although you'll need to re-encode to mpeg2 (again, unwise).
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
duplicated, sorry
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 21:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 21:31 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
editing hd
By devdev in forum Newbie / General discussionsReplies: 4Last Post: 9th Sep 2008, 14:01
