  1. Barney
    Guest
    FFMPEGX converted VCD toDVD, used Audio & Video files with Sizzle to make DVD image.Great results with the menu.
    The Problem is :- Menu works fine on the computer but my stand alone DVD player to TV doesn't. (Have to use title selector on remote control)
    Could this be because the conversion was in ntsc where as my system is pal, but still plays movie ok.
    Cheers Barney
    (Australia)
  2. Barney
    Guest
    No takers????
    So no one will even hazard a guess?
    Well as usual I will work it out by myself.
    Cheers all and Merry Christmas.
  3. Originally Posted by Barney
    This seem quite unlikely. I would suggest to try with another authoring software (like DVD Studio Pro) and to see if you never get a menu, or if you get a menu on some conditions and which ones.
  4. Barney
    Guest
    Thanks Major . I will give that a try.
