I'm under the impression that the + format is better that the - format mostly because it can be played on more DVD players. I'm basing my final purchase of a DVD recorder on it having a + format. Does it really make much difference? I'd probably buy the Panasonic E80 if I have the wrong impression. Thanks
Results 1 to 22 of 22
get a multiformat dude, - and + have been discussed forever, if u want my advice i'd get multiformat so u can make ur own decision
DVD-R is slightly more compatible than DVD+R actually. The advantage of DVD+ is that DVD+RW discs can be edited after recording and play in a majority of ordinary players.
I'd recommend the E80 though as you have a hard disk on which to make all your edits before committing to dvd-r.
The Panasonic machines have a reputation for quality and reliability not matched elsewhere. The drawback is they use DVD-RAM for re-writeable media which is not compatible with most dvd players. DVD-RAM is an excellent format in its own right; however, with the E80 you'll probably only use the hard drive and dvd-r media.
In the standalone recorder market, only the Sony has + and - support. + support is an afterthought though. -
Anyone want to take bets on how soon people will start whipping out their Johnsons and engaging in a royal pissing contest?
Don't sweat the petty things, just pet the sweaty things. -
Same can be done with DVD-RW too. I wouldn't talk about majority...Originally Posted by bobones
or if... then DVD-RW will play on majority players. :P
If you do search on this site you will get:
+RW = 1277
-RW = 1285
+RW and -RW = 942
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
The + format is better and plays on more players?
You musta got that from a Circuit City salesman. One told me that a few weeks ago. :P Do a search, you'll get plenty to read, or are you just trying to stir the pot?
Pull! Bang! Darn! -
DVD-RW can be either compatible (video mode) or editable (VR mode), but not both. The choice has to be made before you burn.Same can be done with DVD-RW too. I wouldn't talk about majority... or if... then DVD-RW will play on majority players.
Hmmm... 44 minutes between my post and donpedro's. Didn't take long, did it? Next time, though, I expect better! 44 minutes is sloppy! C'mon, guys, you're slipping! :POriginally Posted by MJPollardDon't sweat the petty things, just pet the sweaty things.
This is not off-topic forum
There is a mintek that burner's all format's for $300.00 dollars's and read's ever format even SVCD. Do not kow how good it is see them selling it on Home shopping network
To all the smart arses on this thread - we're talking about standalone recorders, not freeking PC burners where you can just go out and buy a dual format drive. If you've nothing valuable to add, just STFU!
Sonny,Originally Posted by SonnyV
OK, here's a totally relevant, direct answer to your question.
Results may vary just a tiny bit, but it's entirely safe to say that DVD-R and DVD+R discs should play just fine in "most" home DVD players. If one works in a few more players than the other, it is just that -- a very few. Choose whatever machine you want, and consider the format totally irrelevant.
DVD-R is supposedly quite a bit more compatible with "computer DVD-ROM drives" than DVD+R, so if your intent is to play that DVD disc you made in a computer drive, there's a clear advantage to DVD-R.
DVD-RAM, DVD-RW, and DVD+RW are NOT compatible with "most" home DVD players or computer DVD-ROM drives -- it's not a safe bet at all that you could, say, hand one of these to a friend or family member, and expect it to work in whatever they've got. On the other hand, if you have, or go out and specifically get, something that'll work with one or more of these, then move forward accordingly.
In the end, any advice that DVD+R is more compatible than DVD-R, or vice versa, especially when just talking about "home DVD players," does indeed sound like "sales droid advice" from some guy who would probably make a bigger commission on the machine he's pushing. Pay it no mind, and get whatever you like the best!
thoots -
If you own a standalone dvd player and want to play your burnt dvd's on it, you should find out if it can play + or - dvd's. If it can play both, then
just flip a coin. Both formats are good. -
I chose by editing features, Fast, quick & easy deleting of TV ads.
I don't want to spend hours converting mp2 > avi and then avi > mp2
to do that.
I chose Cyberhome because:
1 Make chapters of ads
2 make them hidden
3 copy VOBs to any dvdr using Nero6
Following post did it for me:
https://www.videohelp.com/forum/viewtopic.php?t=193511&highlight=cyberhome -
I think you've got that mixed up a bit. DVD-R is a slightly more compatible DVD-Video format, regardless of whether it is read in a DVD-ROM or set-top DVD-Video player.Originally Posted by thootsWant my help? Ask here! (not via PM!)
No it is not mixed up. If you need to read DVD (video or data) on PC. There is much higher chance that you will be successfull wit -R and very high chance that +R will not work on most DVD-ROM drives. When I needed to copy data from +R to PC my score was 6 diff.drives did not read and 0 did read. So you can run into same issue if you need to read DVD Video on PC burned on DVD+R.Originally Posted by lordsmurfPinnacle Studio 8 and DV home video editing (ver.9 already home)
That's opposite of the intended usage though, where DVD+R was initially designed for data and DVD-R has always been for DVD-Video. That's all I've ever seen. I know of at least two drives (DVD-ROM) units that reject DVD-R but will see DVD+R. And inversely, I currently own two players that reject all DVD+R media, but will read any DVD-R. And these instances are not fixed by bitsetting.
It seems pointlessOriginally Posted by lordsmurf
Everybody have different experience. Mine is 6:0 (-/+) on PC DVD-ROM drives. What is your score (don't tell me 0:2
Two cheap ROM drives only took DVD+R and DVD+RW ... about 7 drives took both formats and the RW formats ...Originally Posted by donpedro
The player stats are reversed, with most players taking only DVD-R and choking on all othersWant my help? Ask here! (not via PM!)
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
