Just read the DVD Shrink article on splitting DVD-9 to two DVD-5's without compression. I've done this before, but the only fall back of it is you can't include the Extra Features of the DVD - it is the main movie only!
Article is here:
http://www.polarhome.com:793/~afonic/shrinksplit.htm
So - question: How can we do a third process and place the extras on both DVDs in a similar fashion as DVD-X-Copy? (which does so automatically usually).
You can include the extras using DVD shrink, you just drag and drop the extras. The same way you do the movie, in ReAuthor mode. They will play after the movie, no menus. you have to run the entire DVD thru DVD Shrink.
Actually, you don't re-Author.
You do 1 backup with menu/extra's as stills. You do a second backup with the movie as stills. Now you have full menu's on both disks. 1 disk has extras and the otehr is mostly the Main Movie (minus the 100 MB for the stills). don't forget the extra Audio/Subs if your hurting for space.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Please post DVD to DVDR in the DVD to DVDR forum.. I'm moving this topic.
Adding extra files to DVDs
By kinglerch in forum Authoring (DVD)Replies: 2Last Post: 21st May 2010, 12:59 -
Adding extra folders or files to BD Disc
By jntaylor63 in forum Authoring (Blu-ray)Replies: 2Last Post: 2nd Feb 2010, 13:48 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Adding extra data folders to DVD
By schematic2 in forum Authoring (DVD)Replies: 6Last Post: 25th Apr 2009, 11:01 -
Adding .idx and .sub to .mkv ripped by dvdshrink and handbrake
By theredlaugh in forum DVD RippingReplies: 5Last Post: 17th Dec 2008, 11:11
