Is there any tempgenc template to convert captured DV AVI
(720x480) into half D1 (352x480) DVD compliant mpeg2? I have some VHS home
video that I recaptured through digital8 camcorder.
Under the Video tab, right click on "Size" next to the greyed out 720x480 boxes, select unlock (and ignore the warning) then change the res.Originally Posted by bugster"Art is making something out of nothing and selling it." - Frank Zappa
Also, after you have changed your settings as explained above and gotten your settings just so that produce a file with quality to your liking, lock everything back up and then save as a new template that you can use for your half D1 stuff in the future. That way you have a custom template and all you really have to fiddle with in the future is your bit rate, depending on the length of your videos.
Converting Videos to NTSC MPEG-2 (using TMPGEnc Xpress)
By Quamatek in forum Video ConversionReplies: 14Last Post: 12th Sep 2009, 06:20 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
MPEG video stops half way through playback
By lpmitch in forum Software PlayingReplies: 4Last Post: 4th Apr 2008, 23:15 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
