I want to convert an XVID back to DVD and am having trouble figuring out what aspect ratio should be used. I have tried various software i.e TMPGENC , CCE and mainconcept.
I have followed guides on dvdrhelp.com site using tmpgenc and CCE.
My main problem is that i would like to be able to get the dvd to play back on a 4:3 tv and a widescreen TV whilst maintaining the proper aspect ratio. As if i had bought the DVD from a shop.
I understand that i will have black bars but what ever settings i use i always seem to have much larger black bars than if it where a bought DVD. The same when playing in 4:3 the aspect ratio never looks right.
I believe it has somthing to do with the aspect ratio but some guides will say use 1:1 some 16:9 and some 4:3. i seem unable to find a proper answer as to what should be used and when.
I don't under stand the 1:1 part of it either and am assuming it is because XVID do not contain a DAR.
If anybody can put me out of my misery i would be very grateful
I can't vouch for playback on 4:3 TV but I always use the following:
1. Source aspect 1:1
2. Output aspect 16:9
3. Video arrange method 'Full Screen Keep Aspect Ratio 2'
For a 16:9 source there should be no black bars on a 16:9 TV, for a 2.35:1 source (e.g Star Wars, etc.) there will be small balck bars.
Hope this helps
Jukka -
This should answer any of your questions..great information from the 'Master' DJ- himself:
https://www.videohelp.com/forum/userguides/174200.php -
Thanks for the reply's.
I have already read the guide which was posted.
Whilst i do not understand this fully I think i get the general picture of what should be happening.
What i Really need to know is settings for say TMPGENC (which has already been posted - thanks) and CCE.
As said different guides seem to give different settings
once again thanks so far.
adyk
How to convert squashed DVD aspect ratio back to normal??
By EricBalir in forum Video ConversionReplies: 5Last Post: 9th Sep 2011, 23:36 -
Aspect Ratio?: MKV -> XviD
By Randm in forum Newbie / General discussionsReplies: 9Last Post: 6th May 2009, 12:01 -
Converting VOBs to xVid with 4:3 aspect ratio?
By AOBCD8663 in forum Video ConversionReplies: 2Last Post: 18th May 2008, 21:31 -
Changing aspect ratio on an xvid encode
By SupaDawg in forum EditingReplies: 1Last Post: 6th Jan 2008, 04:59 -
Xvid to DVD with aspect ratio intact?
By StratPlaya in forum Video ConversionReplies: 12Last Post: 5th Jul 2007, 14:02
