Dear friends, I purchased an indiDVD 4x multiple writer... Some how I got a link to upgrade teh fimware to 1.09... Now the computer takes for ever to start.. And once it starts, the dvd drive is not recognized..
TDK told me that 1.09 film was not for US models.. So, I should go back to filmware 1.08.. That will fix the problem.
Now, how do i go back to filmware 1.08? When I click on the exe for 1.08, it does not show me the dvd drive.
Please help.
Thanks, Bhavdeep
download the firmaware for 1.08 from the mfr site.
delete and uninstall drive from win/xp
re-install drive on win/xp
re-flash to 1.08
dont be so quick to just flash away...Corned beef is now made to a higher standard than at any time in history.
Thanks dear friend for that reply.. I have some more problems.
I tried to install the dvd writer on another PC.. I did not install 1.09 on that.. But i get same problem there too. Does that mean that the dvd writer is damaged
Also, what do you mean by "dont be quick in flushing away.."
P.S. I am a newbee in dvd writers.
Can't reinstall or repair Win XP
By PhoneMatt in forum ComputerReplies: 6Last Post: 20th Dec 2011, 08:54 -
How to reinstall XP in a PC that already had XP and Vista?
By Talayero in forum ComputerReplies: 10Last Post: 19th Jul 2008, 05:39 -
DVD Lab how to reinstall?
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2007, 09:48 -
SVCD2DVD Reinstall
By Soapm in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Sep 2007, 04:28 -
GPS. Format or Reinstall... nothing at all?
By Jo The Veteran in forum Portable VideoReplies: 7Last Post: 21st Jul 2007, 10:41
