Just found out, using cdrid, that the new 100 pack of Fuji CDRs are now made by Prodisc Technology Inc and are of the phtalocyanine kind(short strategy). The previous versions were made by Taiyo Yuden and were of the other dye(long strategy), the one that is supposed to be better quality.
My question is, just how bad is the phtalocyanine dye? SHould I not bother burning with these new discs?
I wish there was a guide that would tell you what disc companies use what kind of discs and dyes.
Thx
Mocha,
I am not aware of any T-Y manufactured CD-R's ( under Fuji , TDK or Memorex selling brands) that do not distinguish themselves by the indication on the wrapper that they are " Made in Japan " as opposed to " Made in Taiwan" -
Thanks for the tip. So if it has Made in Japan on them, then itis Taiyo Yuden?
As far as I have experienced. For a long time the more obvious tip off was the packaging of the 50 spindle. The T-Y ones had the screw on retainer "nut" on a cake box cover, while the Taiwan ones were bayonnet style, but in the last year I have seen the former type packaging disappear in my market area.
The packaging of the TY Fuji's has gone to bayonet style. THe base is black and thin, and has a corrugated look. The best indicator, as said before, is the Made in Japan notice on the side. I heard that Fuji dropped TY as their supplier, and will be getting their discs from Prodisc in the future. The TY Fuji's that are available may be old stock and soon to disappear.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 22:56 -
audio out of sync with MKV files, but an inferior computer plays perfect
By dave in or in forum AudioReplies: 3Last Post: 4th Aug 2011, 16:32 -
Question: DVD, CD or ROM DYE LIFE
By mjk4ty in forum MediaReplies: 1Last Post: 10th Feb 2008, 20:18 -
Color of dye on disks
By jbartosh in forum MediaReplies: 3Last Post: 25th Nov 2007, 18:15 -
Best Buy discontunuing (Japan) Fuji CDRs!
By progrocktv in forum MediaReplies: 14Last Post: 21st May 2007, 08:51
