I want to take already decoded vob files and convert them to quicktime. There are plugins that you can get to create screensavers in X but the format must be quicktime. I want to take some clips from movies and convert them to quicktime to accomplish this. I have search to forums but could not find anything.
The tools I already have are:
QuickTime Pro 6.4
MPEG2 Works
DVD2ONE
DVDBackup
If the Thunder don't get you,
the Lighting will. -
you will have to do a little work to get .vob's to be recognized by quicktime.
however, at this present time, mpeg2 decoder isnt working in quicktime so using quicktime is not an option at the moment.
if it were you would simply need to demux the .vob, convert audio into a format quicktime can handle (im blanking at the moment if quicktime can play .ac3 - i believe it can) remux them into an mpeg file which you can open with quicktime when the decoder is fixed.
then its just save as self contained and you have it in a .mov. -
Thanks, galactica
but since it's for a screensaver I don't even need the audio. If the mpeg2 converter starts working again in quicktime can I just open the vob and then export as a mov file? Thanks again, Wayne.If the Thunder don't get you,
well... i believe if you do that the audio will come along
you would need to demux the .vob into a .m2v (mpeg2 with no audio) which you could then open with quicktime when the decoder works!
ffmpegx can do the demuxing for you under TOOLS. it only takes a second or so
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:50 -
quicktime avi file to dvd
By william bowers in forum MacReplies: 2Last Post: 26th Mar 2009, 07:15 -
DVD to something Quicktime and WMP can play
By Hardway in forum DVD RippingReplies: 2Last Post: 13th Aug 2008, 14:22 -
DVD to Quicktime Compatible to Streaming
By ChevyCam in forum DVD RippingReplies: 3Last Post: 14th Apr 2008, 18:31 -
QuickTime DVD Encoding With TMPGEnc
By bigscaryrobot in forum Authoring (DVD)Replies: 0Last Post: 26th Jun 2007, 15:26
