  1. I recently installed the Nero update but NeroVision Express will not load. When I click on the program file it loads the file but the program never comes up. It also prevents me from opening any other programs until I go into the Task Manager and end the NeroVision.exe process. I have tried re-installing, un-installing and going back to the previous version of NVE and I get the same result with that version also. The rest of the Nero components work fine, even Recode. Any ideas as to why this program will not work for me?
  2. I had something similar to this what I id in the end was completely uninstall the whole of nero reboot clear out all nero folders and then reinstall from disk
    It maybe something to do with INCD running in the background ?
    Kwack
  3. After several un-installs and re-installs I have finally fixed it. I had installed the newest VIA 4 in 1 Driver and NV didn't like it. I uninstalled it and NV worked perfectly.
