I am trying to convert a .asx extension file to MPEG2 format, does anyone know the process for this, what program to use, etc. It isn't an extension I usually come across.
Results 1 to 10 of 10
ASX files are textual command files that manage streaming of ASF files. They are very small in size (about 1K) because they contain no data, just instructions. When a user clicks a link to an ASX file, the browser downloads it to the cache directory, launches the Windows Media Player, and then starts the streaming. The advantage of using ASX files over ASF files is their server location. ASF files can reside on different server types
So it sounds like they can't be converted because they are, for lack of a better term, a link to another source. Is that correct?
Use EO Video. It will read .asf & .wmv files. Convert to DIVX or XVID .avi and then use tmpeg to make mpeg2 for dvd
http://www.eo-video.com/
Or just use EO Video's VCD template and burn a VCD... -
so is it impossible to convert a asx file to WMV or something that'll work in TMPGEN?????
How can I convert a mpeg2 and ac3 file set into a mp4?
By woppyvac in forum Newbie / General discussionsReplies: 10Last Post: 5th Apr 2012, 08:01 -
ASX file question...
By mjl1297 in forum Newbie / General discussionsReplies: 7Last Post: 28th Aug 2011, 04:23 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Creating a .asx batch file
By azpuma in forum Newbie / General discussionsReplies: 0Last Post: 3rd Sep 2007, 11:18
