Hi
I used a Panasonic NV-SD275 vcr , and a JVC GR-D30 MiniDV camera.
When i play the 35gb AVI file, the film is sometimes coloured( looks nice) and sometimes white/black (nasty) and the picture "fuzzels"(shows lines).
Is this the macrovision causing this?
Can I fix this using a software or must i have hardware?
Thanks for any help.
Have you tried a home movie on VHS without MV? Not that this will give you a definite answer as I have had a lot of trouble with home movies that are "macrovision protected". But if you have no problems with a home movie MV is most likley your culprit and it's the Cam that's doing it.
Use a Sima Videocopy Master. It inhances the input signal for capture, it will also eliminate protection on DVD and VHS sources.
If it works, don't fix it. -
Hey kidflew,
How did you transfer your VHS footage to your JVC GR-D30?
As I have one also and was wondering how you did it. It is my understanding that the D30 doesn't have an analog input.
E-man
how can i record from the computer to vhs tape?
By NatJm429 in forum Newbie / General discussionsReplies: 15Last Post: 13th Sep 2013, 16:33 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Sony VX2000 - tape or firewire to PC
By porangi in forum Capturing and VCRReplies: 3Last Post: 15th Jan 2011, 16:24 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 21:32 -
VHS tape --> computer
By hubie in forum Video ConversionReplies: 12Last Post: 23rd Jul 2007, 12:59
