I want to capture using an ADVC-100 and I'm going to be capturing to a 120G HD in an external Firewire enclosure. Anyone know if running the capture device and target HD both through firewire will cause any problems?
I don't believe so.
I remember reading part of the manual which stated the HDD had to be connected to the computer, rather than as a standalone type HDD, that seemed to me to be the only proviso.
If you check out the thread I made (ADVC vs ATI) there's a link in there to the ADVC manual, you'll get a better idea from there.
Good luck
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Will Hay wrote:
If you check out the thread I made (ADVC vs ATI) there's a link in there to the ADVC manual, you'll get a better idea from there -
Originally Posted by budz
The post in the thread is exactly the same as the manual.
This is exactly the setup I use and it works like a champ. My PC is an Athlon 1800+ so it's kind of mid-range by today's standards and I never have any problems capturing from my ADVC-100 to my 100GB external, firewire-attached HD.
I checked out the thread and downloaded the PDF manual. unfortunately I found no mention of how the HD should be connected. I don't really trust manuals completely anyway. a lot of people will tell you that something the manual doesn't recommend will work just fine in a real situation. I'm looking more for user input from people who have it hooked up this way. I doubt too many people have that exact configuration though. Thanks for everyone's input though.
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 01:23 -
Help with ADVC 55 Firewire
By wahsac in forum MacReplies: 6Last Post: 31st Jul 2009, 13:56 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 08:39 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 08:15 -
FIREwire HDD, NOT in my computer,update NEW acomdata HDD works great
By theewizard in forum ComputerReplies: 22Last Post: 20th Jul 2007, 01:01
