  1. I have Home Alone 1 & Home Alone 2 on 2 seperate disks and wanted to combine them onto one disc using DVD-Lab. I have re-encoded the video with Main Concepts MPEG Encoder so that they both fit on one disc and the quality looks ok. I have got the menus and Chapter Menus by capturing the frames in WinDVD. I need to get all the chapter marks from the disc so i can reapply them on the new disc. Is there an easier way of doing this other than going through the DVD manually?
    Cheers
    Jamie
  2. Member SaSi's Avatar
    Jan 2003
    Hellas
    You can use SmartRipper to demux the main movie and select no streams. If you however enable the chapter list extraction option, you will get a txt file with the chapter points. You can then apply them faster.
    DVDLab also allows you to import chapters. I don't know what the format is, but you can also export them, so I would mark a couple of chapters and then extract them. This might show you how to edit the Smartripper's chapter list.
    The more I learn, the more I come to realize how little it is I know.
