  1. I've tried making a compilation of .VOB files I've ripped. I used DVTool to cut the beginning off on some of them, and I am unable to put those files into DVD author. I get the following error message:
    Illegal MPEG file
    Does anyone know how to fix this up?
  2. You could try brining the original vobs into TMPGEnc DVD Author and clipping them within the program.
    Hope this helps
  3. I don't have the oroginal VOBs anymore, so I need to fix the cut ones up, so that they are compatible with TMPGEnc DVD author.
  4. You can try to feed them to DVDShrink or DVDFab to rebuild a correct structure.
    Sometimes it worked for me.
    Hope it helps.
    Riccardom
