  1. Is there a free and EASY way to convert all my MP3 to AAC. Thanks.
  2. I have tried following the steps from the guide with the AacMachine but after the normal run it gives me a AAC file with 0 byte.
  3. Originally Posted by amadeira
    Why would you?Converting one lossy format to another lossy format will degrade the sound,you might consider converting to Vorbis by using CDex.
