Howdy all,
I recently purchased a KWorld V-Stream Xpert DVD Maker USB 2.0, model number VS-USB2800D.
It came with the wrong software CD. The CD included was for the Xpert
TV-PVR USB 2.0.
I have downloaded the correct DVD PLUS 3.0 - Capture version software package from Kworld's web site:
ftp://ftp.kworld.com.tw/V-Stream/PVR-PLUS/DVD_PLUS.zip
I need the CD key and serial number for DVD PLUS 3.0 - Capture version. Kworld has not responded to my email. Would any of you be willing to email me a proper CD key and serial number?
Thanks,
Darron R. Birgenheier
Brantingham, NY
darron@birgenheier.com
ICQ 2995851
Results 61 to 63 of 63
I think the CD included is the correct one. It is the one that came with mine and I have been using it for three months.
The best success I have had with that device is to capture and edit with PVR-Plus, then import into Roxio 6 DVD Builder to create menus, transitions and burn to DVD. Like all editing software PVR Plus it takes a little while to learn and I like it once I learned it.
But using that approach Roxio don't let you edit the file (trim and split) with files it did not create. It will crash when trying to burn the DVD.
I burned several DVD's using only Roxio but it drove me crazy with audio sync problems.
Don't use any Cyberlink products to capture, it won't work.
I tried numerous software I found on this site and I always came back to PVR Plus. -
I'm a newbee & just started to try to use this but have a few problems.
The picture quality is very poor with blotches & lies acroos the screen.
Any ideas ?
Can I up from USB to USB2?
By jollyjohn in forum ComputerReplies: 16Last Post: 30th Aug 2008, 10:05 -
DVD Maker
By dd1313 in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2008, 10:15 -
which dvd player with HDMI and USB2 - 5982 not available in belgium
By Roccos in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Feb 2008, 17:02 -
DVD player HDMI + USB2 ?
By Roccos in forum DVD & Blu-ray PlayersReplies: 3Last Post: 5th Oct 2007, 11:30 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 23:18
