I uninstalled the Nimo Codec pack because I was having a hard time with a lot of my XviD files. After much hassle, I was able to get my avi, divx and xvid files to work but now my mpg files won't work! Everytime I click on an mpg file my PC wants to install Easy CD & DVD Creator 6?!?!?
Any advice? Please help a poor man down on his luck.![]()
Curse you Nimo!![]()
hrmmm,
try this,
Click on start, control panel, Folder options, then click on the file types tab. scroll down the extensions list until you see MPG, then associate that file with Windows Media Player -
If codecs problem on XP try this:
Click Start - Control Panel - Sound and sounddevices - hardware - scroll down to Videocodec - click properties - properties again (flag), and you will find a list of all codecs installed on your computer.
Now you can remove those that gives you any problem......000....000....
Angelot :-D
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 15:42 -
Office 2007 can't be uninstalled
By ukb007 in forum ComputerReplies: 3Last Post: 15th May 2011, 09:51 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
Codec Trouble
By Legion273 in forum Video ConversionReplies: 10Last Post: 10th Jun 2008, 01:42 -
Media Centre CyberLink programs accidentally uninstalled- please help!
By Joanna in forum ComputerReplies: 7Last Post: 16th Nov 2007, 13:24
