Results 1 to 18 of 18
    Dec 2003
    Norway
    I recorded about half an hour with huffyuy 640x480, and I used mp3 96kb as audio, after about 20 mins, the sound became more and more out sync...what can I do to prevent this? will it help to use another audio-codec?
    and while I got a topic running, what prog is the best to use when encoding to xvid? I saw some other post saying that tmpgenc wasn't that good with xvid.....
    canada
    I use virtualdub and it stays on sync all the time with `adjust video clock dynamically to match audio clock` checked in the timing.tmpgnc does fine for me and if i get any problems i change the header of the avi to divx with the 4cc changer.
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Well I don't know what kind of capture card you have or how fast your computer is etc. but usually it is a bad idea to capture using anything otherthan PCM WAV audio.
    If you plan on doing an Xvid then you probably should use 16-bit 48k Stereo WAV
    - John "FulciLives" Coleman
    Dec 2003
    Norway
    my computer is listed in computer details, as well is my capture card...
    and how much extra space will wav add?
  5. Member FulciLives's Avatar
    May 2003
    I see you have a VIA chipset on your motherboard. This has been a known audio sync problem. I think they have updated drivers for it. If I recall the problem is isolated (again I think) to built-in MB audio and not if using a seperate PCI audio card.
    But try PCM WAV audio and see if that helps. It makes the file size much bigger but you can convert to MP3 audio while converting the video to Xvid and then delete the original capture so ... who cares?
    Dec 2003
    Norway
    I got all the latest drivers...I'm just low on space right now, waiting for new hd...
    I can't seem to use virtuadub though, I always get the 418 error when setting capture resolution, and I've seen it happen to alot of other people, has anyone solved it yet? for now I'll just have to use winfast pvr...
    Dec 2003
    Norway
    also my mobo uses software audio instead of hardware audio, not sure what that means, but is it crucial?
  8. I'm a Super Moderator johns0's Avatar
    canada
    Try different settings for your video format thru custom settings.640x480 is usually standard and change the data format to UYUY and see if that works,if not then try another data format,software audio is onboard and shouldnt be a real problem unless you are dropping frames cause of it being that it uses extra cpu processing power.
    Dec 2003
    Norway
    no the frames are fine, it's just the audio going out of sync, I wish I could run virtualdub in more resolutions than 320x480...I'll try capturing with wav tonight to see if it's solves the problem, although I fear the space it'll take...how much would a minute of that wav-setting you suggested take up?
    edit:
    pcm doesn't let me chose bitrate though, is this normal?
  10. Member FulciLives's Avatar
    May 2003
    PCM WAV audio has a fixed bitrate. You should choose 16-bit 48k (not 44.1k) STEREO WAV file.
    VirtualDub really only works if your capture card uses VFW drivers but most capture cards actually use WDM drivers ... and when you use such a capture card with VirtualDub you can't capture past something like VCD resolution.
    So if you are getting the resolution error it is most likely because your card uses WDM drivers. In that case forget using VirtualDub for capture.
    Look into VirtualVCR or iuVCR or TheFlyDS
    All three work well with capture cards that use WDM drivers which means of course no resolution restrictions.
  11. I'm a Super Moderator johns0's Avatar
    canada
    Im using virtualdub 1.1.43 with wdm drivers and no vfw wrapper and it captures at up to 720x480.
    May 2002
    louisville,ky
    in virtualdub open your capture window and then go to video...select custom format and see if you can change your resolution to what you want
  13. Member FulciLives's Avatar
    May 2003
    I can't imagine how that is possible!
  14. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    I second the VIA suggestion.
    I never solved my problems until I switched to a motherboard with an SiS chipset.
    Countless latency programs and patches never solved my VIA issues.
    From my experience I'll never buy VIA again, not because they're bad (although they were for me in capturing) but because for me it isn't worth the risk.
    I heard it affected older chipsets the most (KT133 for instance, if I remember correctly) but like I say, not worth the risk.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  15. Member Leoslocks's Avatar
    May 2003
    I am using Virtual Dub 1.5.10 on W2k and can capture at 720 x 480 from svhs tape. I think Direct X has a VFW wrapper included with the Direct Show part of drivers. I am using DirectX 9.0b.
    I would rather use Virtual VCR but the color is all messed up.
    Dec 2003
    Norway
    I downloaded the virtualvcr-mod for my capture-card...it said it found channels, but when I tried preview it failed....
    edit:
    got the preview working, but for some reason all the channels look scrambled...
    Dec 2003
    Norway
    ok, I've hooked up the cable box through the s-video port to get hbo, but now all I get in virtualvcr is a blue screen, the sound works though...I get normal picture in winfast...
  18. Originally Posted by johns0
    You are using Windows XP, therefore the wrapper is already installed.
    Which drivers are you using, the IULab one or the BTWDM ?
    If you are using the BTWDM then the higher resolutions work without a problem.
