I've changed the laser unit in my sons PS2 but it still won't play DVDrs---------------Do i have to do any adjustments?------------it's a year old V7.
I've spent £50 on the unit , so i've got to get the mutha working properly!!!
All advice /ideas appreciated.
'MIGER'
Results 1 to 12 of 12
you might try different dvd-r media..
but you can also try adjusting the POTS.. its a little white round disc towards the back of the dvd-rom drive. make sure you remember its original location prior to adjusting it, and make sure you only adjust it when the ps2 is off. -
http://www.gamefaqs.com/console/ps2/game/26308.html
Try that link. there are severl FAQs dealing with laser cleaning and calibration in a PS2. No pictures though only test guides there. -
Hey Jeex the pots are the potentiometers they control the amont of current going to the laser the 2 tiny metal screws that you can adjust using a multimeter and a pot adjuster.Originally Posted by jeex
That gear controls the height of the laser on the carriage assembly I think its called an azimuth gear if I am not mistaken.
IMHO
You really should try to adjust the pots unless you are not capable of reading an original DVD. Pots are very sensative and if you go too far you can kill your laser or might not ever get it to read media correctly.
However adjusting the gear Just as you said would probably be something for him to try first. Its very easy to undo I ususally take a sharpie to put a mark for the gears original adjustment (at 12 o'clock straight up position) and just turn a few clicks at a time.
I would recommend a gear adjustment first and the pot adjustment as a last resort. -
Originally Posted by miger
So do you hear any ticking?
Were all DVD-R reading properly initally?
Did you chip it?
Is it going to the disk browser screen (screen with black disk/memory card)?
Are you gettting the RSOD (Red Screen of Death)? -
Hi & thanks for ALL the advice --------------------
Ps2 daddy:
it makes a 'whirr' sound before it spins
it used to play any DVDR media,
it is chipped ,
Yes it goes to the browser screen
& no, i've never had the red screen,
Thanks again Guys.
'Miger' -
Humh sound like its trying to recognize the disk since you are not getting the RSODOriginally Posted by miger
Since you changed the laser it might be the chip double chek all the wires with multimeter and make sure you have firm connections.
Did you get a new laser or refurbished?
Did you desolder the ground straps? (if it was a new laser) -
-----------it was a whole new laser unit -
http://www.psxservices.co.uk/images/ps2/PS2_laser_install.pdfOriginally Posted by miger
You only have to do this if you only got a laser if you got the black plastic assembly with it then this isnt necessary. -
it would probably cheaper to go and buy a DVD player at Target or Waly World than tryin to get it to play the dvdrs. V7 should play dvdrs, i know that my buddy's V2 doesnt play em for a fact, the laser isnt powerful enough, but my V5 plays em.
-------------------sure, but i need to play DVDR PS2 games!
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 22:32 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
Can the PS2 play divx avi movies?
By amjad_z4 in forum DVD & Blu-ray PlayersReplies: 30Last Post: 14th Jul 2010, 06:52 -
Laser Etching DVDR That are NOT Light Scribe Discs.
By Scooter_NJ in forum Authoring (DVD)Replies: 4Last Post: 17th Nov 2008, 19:11 -
LCD Monitor I can play my PS2 on?
By oroboro in forum DVB / IPTVReplies: 3Last Post: 22nd Apr 2008, 09:54
