I'm trying to convert DVD to VCD using smart ripper, DVD2AVI and TMPGenc. I managed fine using the guides here, but the audio is too low.
I know smartripper is not the problem, because if I play the vts_01_1 file in ATI player, the sound is fine.
The problem seems to be DVD2AVI. The WAV file it creates is quieter than the original DVD.
I have normalization 'on' and set to 100%.
Anyone had this problem, or know why it's happening?
We'll be right back after these messages from Binford!
After much playing about, I've managed to make it a bit better.
I turned on 48 > 44.1Khz, and set it to low.
The sound is now almost as good as the original.
Has anyone else done this, or know if there is still something I'm missing?
Thanks.We'll be right back after these messages from Binford! -
normalization set to 100% ... this means you are not changing the volume of the audio at all! less than 100% is lower.. more than 100% is higher
Tmpgenc wizard... expert settings...audio tab..... audio edit...
tick change volume then 200% .. works for me every time.... even the neighbours enjoy my films now.. -
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 11:39 -
normalize volume
By lj01 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2009, 14:05 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28 -
turning up volume
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 27th Aug 2007, 01:03
