Using DVDlab 1.3 ive found out that theres no way to flip objects or rotate them? what can i do? also whats the difference between DVD menu studio and RealDrawPro??? mostly im intrested in an app that can design stuff so i dont have to make stuff on pshop or illustrator. whats my best option from the app si mentioned???
I guess in theory DVD menu studio since the two apps are designed to work together
On the other hand I find the lack of alignment controls to be very annoying
I would shoot for DVD Menu Studio though -
This alignment in DVDlab really sucks. It probably was designedOriginally Posted by D_Knife
to help in menu creation from scratch. But if one needs just to
adjust something, it screws everything.
There are other disappointments in DVDlab as well, but still
it is quite good, maybe the best, - I didn't try DVDMenu Studio yet. -
there's a 30 day trial of DVD menu studio
I let the trial expire although I bought - actually purchased DVD-Lab!!!!!!
this is pretty much a first :P
but I agree with you how alignment gets screwed so easily
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 19:04 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 15:09 -
DVDLab Audio Playback
By alhall in forum Authoring (DVD)Replies: 1Last Post: 26th May 2008, 10:00 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 05:55 -
problem with dvdlab pro2
By postie1392 in forum Newbie / General discussionsReplies: 10Last Post: 27th Sep 2007, 07:00
