I was 51% through encoding and I got the error Invalid Floating Point Operation. Can someone tell me what this might be. Thanks
Let's see, you're using TMPGenc and are trying to convert a movie. The avi has bad frames, so TMP crashes on it.
What I do is frameserv the movie from v-dub to TMPGenc, and my problems are solved. Never failed yet. (Knock on wood) -
yep. Floating point errors almost always come from frozen frames in AVI files. i once downloaded a movie with frozen frames in thE AVI file, and encoded it without error, when i burnt it, all the frozen frames were there and the qudio/video sync was affected. I actually only encountered the error when i used version 12a to encode. When it came to the frozen frame, it stopped encoding and gave the floating point error, all the later version encoded after the frozen frames, and didnt enoucnter the error
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
AG-1970 operation question
By jcolegrove in forum RestorationReplies: 3Last Post: 12th Apr 2010, 12:35 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47
