I recently purchased this drive and have a couple of problems. I am a relative newbie to the DVD writer scene and I do not know how to flash the firmware on the drive. I have searched many forums but no luck. I have downloaded the flash files from ASUS but there was no instructions?
I have an .EXE file and a Firmware file. I tried running the EXE with the firmware file i.e. >flash.exe fw12345 the flash EXE runs but then sais something like “Cannot locate target” or something similar. I just tried running them from WinXP start menu, run and dragging the firmware file onto the EXE in file explorer.
How can I get this working? How do I execute the flash file.
I have Daemon Tools running which uses a virtual DVD drive to mount images from the HDD should I uninstall this before attempting to flash? Maybe its getting confused with this virtual DVD drive?
The drive is working but I noticed when I burn a DVD using Nero 6 it takes about 35mins at 4x speed? I am using Princo Media. The resulting DVD works fine but shouldn’t it take about 13-15mins?. The weird thing is Nero sais 13 mins to completion (once the DVD starts writing) then it goes past this by another 20 mins saying -20 mins (negative) upon completion.
Would upgrading the firmware fix this problem with Nero? It appears to be reading/writing the Princo DVD-R media at 2x not 4x??
Has anyone else had these problems?
Please help.![]()
Results 1 to 1 of 1
I think My ASUS DRW-20141T Is Dieing??
By xintensex in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Oct 2010, 01:58 -
Magnum DRW 9500
By Topp in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Feb 2009, 21:31 -
Asus DRW-1814BLT Freezing Computer While Working
By mightymo77 in forum DVD & Blu-ray WritersReplies: 5Last Post: 1st Nov 2007, 11:54 -
New Asus DRW-1814BLT Sata 18x Burning slowly Nero7
By DAVE440 in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Sep 2007, 02:16 -
ASUS DRW-1814BLT SATA Cables needed?
By Choppa in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Aug 2007, 00:21
