I am trying to split a divx avi that is 1.4 gigs into something more managable for cdrs. That part is easy with Virtual Dub.
My question is I have one large .srt file for the entire 1.4 gig avi. Is there a way to still use this file for the splits? Can I leave it as a single file and the separated avis will still recognize it?
Or should I split the srt up also and name the files like
avi1.avi
avi1.srt
avi2.avi
avi2.srt
And just manually cut/paste the subs into their respective parts?
Interesting problem you have there.
The first problem is that once you split the AVI file into parts, then you don't have valid .srt timings for the second, third, ... parts. As the .srt file is a single one, timing in there is based on 0:00:00.00 time for the first frame of the AVI.
If you split it, say, at 30 min, then you should split the .srt file appropriatelly and "retime" the subtitles so that you remove exactly 30 minutes out of every one.
I don't know of a program that can help you there - but have not dealt with AVI subtitle streams much.The more I learn, the more I come to realize how little it is I know. -
Subtitle workshop can split srt subs and it fixes the time codes.
I was afraid you were going to say that. There's no way I'll take the time to hand correct the timings.
What if I embedded the subs into the original avi first, then split them in vdub? -
ahh very cool. It looks like I can split it at the same frame as i use in vdub, Baldrick. Is that corrent? Just split the srt at the exact same frame as I split the main avi at?
And this will retime the the second srt to match the second avi?
Splitting Divx
By acestu in forum EditingReplies: 2Last Post: 24th Jun 2009, 20:21 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 16:36 -
Directly ripping hardcoded subs on DivX/AVI from DVD
By drstupid in forum SubtitleReplies: 2Last Post: 4th Jan 2008, 15:51 -
How do you convert DivX file w/4 subs to AVI?
By JoeBolden in forum Video ConversionReplies: 2Last Post: 21st Nov 2007, 14:58 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
