evening all, right the prob is..............at first my tmpgenc wasnt reading my mpegs so i thought i was fooked. then i gave cybre high pro. now tmpgenc makes a file, a bit like a cue file so it now reconises my mpegs. but for some reason my 700 meg mpegs r reading at 2gigs? well some r and some arent? any ideas?
Results 1 to 9 of 9
kinda new to this he he
What's that?Originally Posted by london
Don't know what that means either.Originally Posted by london
If I had any idea what you are saying I could try and help but your post is too confusing. Try explaining from the very beginning what you are trying to do. What are your source files? What programs are you using? Explain your method and settings step by step. Only then can someone try and help.Originally Posted by london"Art is making something out of nothing and selling it." - Frank Zappa -
hows this for plain english..............when trying to make dvd mpeg using tmpgenc, in step2 >2< (two) for those who dont understand!! i put an mpeg in the source file.... then i go to step3 >3< (three). then i go to step 4 >4< (four). now in the MAKE file size box u get the option to make the size of the file!! you with me so far..... now this 700 (seven hundred) meg file is not going any smaller then 2 gigs (2000 megs). any ideas
i hope this is a bit more clear for u zippykinda new to this he he -
You're post is still not that clear I'm afraid.
The steps you're talking about are in the Project Wizard in TMPGEnc, I presume.
So is the source file a 700mb MPEG?Originally Posted by london
How do you mean is not going any smaller? How are you trying to make it smaller?
We can all read numbers - but not minds
cheers,
mcdruid. -
Also, what template are you using to re-encode your file ?
Reduce the bit rate.
dlb. -
If you are trying to make a DVD, and you are in fact using the dvd template (meaning that you selected DVD NTSC or DVD PAL), then assumes that you are trying to put the file on a DVD disc, which has a capacity of 4.7gigs. So, this is why the file is so large (i think), because the bitrate is in the range that dvds use, which takes up much more space.
change the settings to VCD NTSC or VCD PAL, and you will get more compressed file, with lower picture quality, to fit on CD-R/RW though if your source file is 700 megs, i'm assuming it is longer than 80minutes? You will likely need to split it across two discs...asdf -
im using pal and nstc templetes. even though the file size starts of as say...2.5 gigs u can make them more nearer the 700 megs.
Tmpgenc Authoring Works Version 4.0.7.32 - November 9, 2009
By juliocesar in forum Authoring (DVD)Replies: 3Last Post: 27th Nov 2009, 06:05 -
Super C Problems - Recent Version
By PowerFalcon in forum Video ConversionReplies: 6Last Post: 18th Jun 2009, 20:04 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 10:25 -
Any problems with Xvid latest version and AVIReComp?
By Relayerman in forum Video ConversionReplies: 1Last Post: 30th Jan 2008, 11:00 -
new version problems
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 4th Oct 2007, 12:15
