I have one VHS video I'd like to convert to VCD. I have a video card with a TV out port on it, plugged up my VCR to it. I figure I could do video then do sound, then put them together in an MPEG, then convert to VCD.
I downloaded Virtual VCR but it won't detect anything. Is there something I'm doing wrong?
I dont have a TV tuner card. Do I really need one? If so why do video cards have TV/out ports? I know I could hook it up to my TV for a monitor and to watch stuff on, but even so it'd be audio or video only.
I plan on getting a TV tuner card eventually, any suggestions? -
You need a card that can capture video. If you video card has TV out, and has no way to put video into your computer, you cannot convert VHS to MPEG with your TV card.
You should look at the guides, try to decide what you might need. A simple TV card with video in and video out will do what you need, provided you learn how to use the bundled software.Hello. -
Thank you for clearing that up to me, I guess that does make sense. I had planned on buying a TV tuner card, but am trying to save up for a vehicle. Guess I could splurge just once. Thanks again
Make sure you buy a card that can capture,tv-out just means it can display stuff to your tv.
Synced audio track eventually becomes out off sync
By brent1a in forum AudioReplies: 1Last Post: 18th Nov 2010, 13:58 -
is there a simple way to convert an avi to vcd?
By lks9042 in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2009, 03:00 -
how to convert dvdrip avi's to vcd
By kissme1 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 9th Dec 2008, 15:19 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:51 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
