I'm hopeing to squeeze a bit more space out of a MiniDVD disk, is there anyway to go about forcing Nero to burn MiniDVDs in Mode2/XA? Or would the removal of error correction be a bad thing for a MiniDVD? I know it works well with VCD and SVCD, I figured the case would be the same.
There is a program called Mode2CDmaker,I believe you can find it in the tools section. It makes an image file of your 800MB directory which you can then burn as an image file with Nero. I only made one disk,it played in one DVD player as a normal miniDVD but in another it played in slow motion. Sampo 612 played it,Cyberhome 402 played in slow motion.
I must try this ... however I remember looking at nero and there is an option for making things burn in mode2 .. goto burn cdr then ISO tab then the option is there in front of you.. havent tried it, so cant vouch for it... I am interested in testing the quality of minidvd as opposed to svcd .. the big problem was that svcd can store an extra 13% becoz of mode2 thus making a comparison difficult.
The electronic components of the power part adopted a lot of Rubycons.
MiniDvd Ripping Issue Nero 10
By OnThreeGo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Dec 2010, 13:00 -
Creating MiniDVD
By MI6 in forum Authoring (DVD)Replies: 7Last Post: 21st Nov 2008, 00:05 -
Can you capture from a MiniDVD camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Sep 2008, 22:52 -
Finalize Sony MiniDVD on PC
By schematic2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2007, 22:55 -
Using files from a MiniDVD Camcorder
By djc38510 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2007, 10:57
