On 2001-05-29 13:11:24, Sefy wrote:
I Suggest for those that are having problem extracting the WAV because of size, try using ReMPEG 1.5x to extract the AC3 into a MP2 file which will be much smaller then WAV and you can use it in TMPGEnc to Multiplex/Encode with the D2V file.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Thanks.
I'm extracting the .mpa file from the VOBs as I write. I suppose I'll still need to generate a .d2v file to instruct TMPGEnc how to reassemble things. Do I use ReMPEG for this or do I use AVI2MPG (and simply throw away the currupt .wav file)?
Unfortunatly to create a D2V file you still have to use DVD2AVI, but to save time, you can tell it to not Demux or Decode the Audio Track, since you already have it in MP2 format.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
OK, after about 12 hrs of processing I've got a .mp3 file (at least that's what the program suffixed it). I've listened to it using MediaPlayer and it sounds good (except for some distortion during the THX advert) and complete. Unfortunately TMPGEnc doesn't like it after processing for a few seconds. Maybe I can fix it or convert it back to .wav using some other utility? -
You could uncompress the MP3 into WAV using any WAV <=> MP3 program on the market, that shouldn't be a problem.
Best Regards,
Sefy Levy,
Sefy,
Can I rip only the audio w/ DVD2AVI?
I would like to have a second audio, so I don't want to rip the video again.
Thanks.
BeTa -
That's an interesting question, I know you can do Video Only, but i'm not sure about Audio Only, check the Video Options, I haven't browsed much through them, but if you only want Video, I think you can just Demux the VOB using Smart Ripper for example and create an M2V file.
Best Regards,
Sefy Levy,
There must be something wrong with the .mp3 (though both MediaPlayer and WinAmp have no problems). Two programs abnormally terminate with a VB C++ run time error right at the end. WinAmp says "Waveform-audio file has no "FMT chunk" -
Have you tried using ReMPEG2 to rip the Audio Track from the VOB files ?
Best Regards,
Sefy Levy,
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
