  1. Ive looked on the forum and guides and I was unable to see a guide on how to remove subtitles from an avi (DivX 4 if thats important).
    Also, there are some subtitles on the original movie, will they be okay?
    Thanks in advance.
    Yours,
    Beev
    Yours,
    Beev
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    SORRY CAN'T BE DONE
    THE SUBTITLES ARE MARRIED TO THE VIDEO
    Divx cannot support "layers"
    You should do some reading of those GUIDES you speak of!!!
    I don't understand the other question
    OKAY TO DO WHAT?
    Are You making this divx file from an original movie (that someone else made with 'subtitles')?
    If its a DVD..yes you can usually make the new file discarding the subs
  3. "Are You making this divx file from an original movie (that someone else made with 'subtitles')?
    If its a DVD..yes you can usually make the new file discarding the subs"
    It is actually a documentary that I downloaded. There are a few interviews that are given by people who speak in a foreign language, they have original subtitles in the interviews.
    However, the video has a second set of subtitles that have been added that span across the entire duration of the movie.
    So what I meant was would I be able to just get rid of the added subtitles and then keep the subtitles that were a part of the original movie.
    Yours,
    Beev
