When I create a mpeg2 to be played on my TV using TPMGenc, I notice that I have to use 480 for width and 576 for height instead of vise versa. This is the only setting my DVD player (lenco) will accept.
Does this make sence?
cheers
Leo
lmichiel, VCDs and SVCDs don't use square (i.e., 1:1) pixels. You will have to get used to the concept of display aspect ratio which is completely separate from the physical dimensions of the video.
Both VCDs and SVCDs have a DAR of 4:3, which means whatever their physical dimensions LOOK like on a 1:1 pixel display (i.e., PC monitor), they will be forced to display with an aspect ratio of 4:3 (i.e., full screen TV).
Regards.
Michael Tam
w: Morsels of Evidence -
Thanks all, next question though:
How do I make a mpeg which looks good on a PC (1:1) and good on a DVD player (4:3)
Can I use the following setting in tmpgenc:
On video tab: Aspect Ratio 1:1 and on advanced tab Source Aspect Ratio 4:3
cheers
Leo
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 18:31 -
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 18:40 -
16:10 Aspect Ratio
By SWBisbee in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2008, 02:41 -
Aspect Ratio
By mistycat in forum Video ConversionReplies: 8Last Post: 8th Nov 2007, 03:43 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 14:27
